  3. pss pac: sideband transfer function accuracy vs. maxacf...
  • Views 11565
pss pac: sideband transfer function accuracy vs. maxacfrequency
ashwinrs
ashwinrs over 4 years ago
Hello all,
As far as I understood, the time-step for pss shooting depends on "maxacfrequency" which defaults to max(pss output harmonics,10)*4*fundamental_frequency, and the error preset. This, in turn, will determine the accuracy of the subsequent periodic small signal analysis. I did the following experiment. For a linear periodically time-varying circuit, I ran pss with zero harmonics (which means maxacfreq = 40*fs, where fs is the pss beat frequency). I checked the transfer function from an input frequency "fin" to an output frequency at "fin+15*fs" by running a pac analysis and checking the transfer function around the 15th sideband. Next, I gave "maxacfrequency" to be equal to 5*fs and checked the transfer function from fin to fin+15*fs. The result was exactly identical. I expected that since the maxacfrequency is set to 5*fs, the small signal analysis will not be able to estimate the transfer function around the 15th sideband accurately. But it doesn't seem to be the case. The error preset was set to "liberal" in both the experiments.
Please help me understand what is happening here. And what is the relation between the pac sideband transfer function accuracy and the maxacfrequency (or the output harmonics set in pss).
Thanks in advance!
    The minimum for maxacfreq is 40*PSSfund, so setting it lower won't have any effect. Note that if you have sharp transitions (for which the PSS may end up taking short time steps to follow), you might have greater accuracy than you anticipate - the maxacfreq is there just to force sufficient time steps to get spectral accuracy - normally determined by the maximum harmonic you ask for. There's a little further margin too because usually the time step will be controlled to have at least 5 points per period of maxacfreq.
    Note from the "spectre -h pss":
    The `maxacfreq' parameter is used to automatically adjust the `maxstep' and
    reduce errors due to aliasing in frequency-domain results. By default, the
    `maxacfreq' is set to four times the frequency of the largest requested
    harmonic, but is never set to less than forty times the fundamental.
