  3. Transmission Line Simulation in EMX
  • Subscribers 137
  • Views 14812
Sumit Dash
Sumit Dash over 4 years ago
Hello everyone,
Can some one help me in how to do the transmission line (both Single ended and Differential) simulation in EMX ? I couldn't get any document from cadence either explaining the same.
  • drdanmc
    drdanmc over 4 years ago
    This topic has pointers to documentation.
    https://community.cadence.com/cadence_technology_forums/f/rf-design/45537/documents-for-using-emx-for-em-simulations-of-inductor-and-transmission-line
    The really short answer is you create a layout use pins to define where ports will be and then EMX generates s-parameters.  If you have something like a differential transmission line you will end up with a 4-port network.  You can pull that into a spectre simulation with the nport device or load the file into something like python with scikit-rf and plot the single ended s-parameters and also convert to a mixed mode network where you can plot differential-to-differential, common-mode-to-common-mode, or differential-to-common-mode s-parameters.
