  3. Can I hide the gray rows in output results table?
  • Views 11183
StephanWeber
StephanWeber over 4 years ago
Hi, after MC, in Detailed-mode results table, I applied a filter to see only the critical samples. But the result is not easy to read:
So I many columns which show no useful information, even not any results data at all. And to see the interesting rows I need to scroll a lot. If multiple interesting rows exist, then they are often spaced widely apart from eachother.
Can I prevent this, and suppress the gray row without data below?
Bye Stephan
    Not currently. You asked for this when you worked for Cadence - CCR 1845652. One other customer has asked for it in the meantime (as a minor enhancement)
    You can of course use the Detail Transpose where the column filtering makes more sense anyway (you can enter a filter per measurement, which is rather more targeted). You don't then get the grey lines on the Detail Transpose view.
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    I like Detail Transposed too, and use it often, but the transposed view has also its disadvantages, like you do not see the test names.
    Andrew Beckett over 4 years ago in reply to StephanWeber
    You can show the test name:
    The test name then appears above the output name in each column ("DC" in the above picture).
