  3. Cadence Viva - customizing traceLegend font size
  • Views 4369
firebolt
firebolt over 4 years ago
Customizing traceLegend font size is not working for me both from envSetVal & Graph Properties. It's fixed to 9 only. Please help.
Virtuoso sub-version IC6.1.8-64b.500.26 (64-bit addresses)
envSetVal("viva.traceLegend" "font" 'string "Clean,20,-1,5,55,0,0,0,0,0")
    This is because this is the only size that is available for the Clean font on your system. If you use a KDE application (e.g. konsole ) and then Settings→Edit Current Profile→Appearance Tab and then pick…
    This is because this is the only size that is available for the Clean font on your system. If you use a KDE application (e.g. konsole) and then Settings→Edit Current Profile→Appearance Tab and then pick the Font on that UI, you'll see the same choice available:
    Other fonts are available which do support larger sizes.
  • firebolt
    firebolt over 4 years ago in reply to Andrew Beckett
    Thanks Andrew.
