  3. ADE Assembler: Strange corner GUI observations
  • Views 10403
StephanWeber
StephanWeber over 4 years ago
in Run Summary assitant I can see if corners are enabled, and how many. I remember in the past I could click to the checkbox and enable/disable all corners from here. However, in my current work env, this checkbox is grayed out, and I do not know why. Can I re-enable it with some env variable?
A 2nd issue: I load a default corner template via SDB file. And this file has nominal enabled. However, after starting maestro (with loading the sdb file), I got the nominal disabled.And in Data View the checkbox is also not active.
So after startup of maestro, I always need to go to the Corner setup tool, which is a bit bothering.
Is there any reason for this strange behavior?
Bye Stephan
    Check envGetVal("adexl.gui" "disableNominalSimulation") . If this is t, then try:
    envSetVal("adexl.gui" "disableNominalSimulation" 'boolean  nil)
    (you'll need to restart the ADE window after changing it, I think).
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    Thanks for the hint. I put the envSetVal to cdsinit, but it seems our CAD is still setting it to t (after cdsinit execution).
