  3. Adexl - auto locking Interactive when run finishes
  • Replies 9
  • Views 5183
firebolt
firebolt over 4 years ago
Is there a way to auto-lock the Interactive history when the Adexl job is completed?
    Andrew Beckett over 4 years ago in reply to firebolt +1
    The code only works if envGetVal("adexl.historyNamePrefix" "showNameHistoryForm") returns t and envGetVal("adexl.historyNamePrefix" "initiallyAddHistoryNameUniquifier") returns nil - I thought that was…
    I suspect it could be done by writing a trigger to lock when simulation has completed (using axlSetHistoryLock, probably in the runFinishedConclusion or runFinishedPostPlot trigger (see axlSessionSignalList() and axlSessionConnect()), but I've not tried. It would be a bit of a pain this way to turn on and off (although could use a global flag to do it, I guess). I didn't try writing such a function though - doesn't sound too hard though.
    Alternatively you could just increase the "Save N entries" on the Options->Save form in Assembler to stop the histories being deleted automatically.
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    This code should do it (I thought I'd check that the idea I suggested above worked):
    /* abAutoLockHistory.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Sep 04, 2022
    Modified
    By
    Allow histories to be automatically locked when simulations are
    complete. The code example below uses a combination of the
    showNameHistoryForm and initiallyAddHistoryNameUniquifier to turn this
    behaviour on or off, but the condition could be changed as you wish.
    To enable: abEnableAutoLockHistory()
    SCCS Info: @(#) abAutoLockHistory.il 09/04/22.06:52:13 1.1
    *               abAutoLockHistory(_sess _runId hsdb)               *
    *   Trigger to automatically lock the history. Only does so when   *
    * the history name form is shown and adding the suffix is disabled *
    *          (you can change the condition as you see fit)           *
    procedure(abAutoLockHistory(_sess _runId hsdb)
        when(envGetVal("adexl.historyNamePrefix" "showNameHistoryForm") &&
                !envGetVal("adexl.historyNamePrefix"
            axlSetHistoryLock(hsdb t)
    *            abEnableAutoLockHistoryTriggers(sess)             *
    *  Add the trigger when the ADE XL/Maestro session is started  *
    procedure(abEnableAutoLockHistoryTriggers(sess)
        axlSessionConnect(sess "runFinishedConclusion" 'abAutoLockHistory)
    *                  abEnableAutoLockHistory()                   *
    *     Enable auto-locking of histories when run finished.      *
    procedure(abEnableAutoLockHistory()
        axlSessionRegisterCreationCallback('abEnableAutoLockHistoryTriggers)
  • firebolt
    firebolt over 4 years ago in reply to Andrew Beckett
    I tried this. Not working. Retuns nil.
    envSetVal("axlSetHistoryLock" "runFinishedConclusion" 'boolean t)
    Hardly surprising since I didn't say these were environment variables. If it had been that simple, I wouldn't have said "I suspect it could be done by writing a trigger to lock when simulation has completed". That's more than just an env var - it needs some SKILL code.
    I then (in my last post above) expanded upon the functions that I thought would be necessary (and the trigger that would be needed, i.e. runFinishedConclusion) and gave some SKILL code that showed this working.
  • firebolt
    How to use this skill code? I tried loading in CIW. It's not working.
    load "<full_path>/abAutoLockHistory.il"
    Two things:
    1. read the comments at the top of the code which tell you how to enable it
    2. it will only affect ADE Assembler sessions started after you enable the auto-locking. You’ll have to close and reopen any existing ADE sessions
  • firebolt
    Closed Adexl. Entered 2 commands in CIW. Opened Adexl. It's not working. What am I missing here?
    The code only works if envGetVal("adexl.historyNamePrefix" "showNameHistoryForm") returns t and envGetVal("adexl.historyNamePrefix" "initiallyAddHistoryNameUniquifier") returns nil - I thought that was a reasonable way to enable auto-locking - if you'd explicitly set a history name which didn't add the suffix - but you might want to change that logic in the code. Was that the case in your environment?
    Note you should not load and enable the function more than once in a Virtuoso session, and if you change the logic in the code, then it would still continue to use the old logic. So if you change it or enable more than once, you should quit and restart virtuoso because it doesn't disable the existing trigger and doesn't check to see if it's already registered (I kept the code simple).
    Note you can change the settings of showNameHistoryForm and initiallyAddHistoryNameUniquifier after you've enabled the trigger; it looks up the values at the time of simulation completion and uses whatever they were at the time.
  • firebolt
    Thanks Andrew. Yes, setting showNameHistoryForm & initiallyAddHistoryNameUniquifier to proper values helped me. It's working now. Interactives get auto-locked after run completes. Commands used in CIW before opening Adexl:
    envSetVal("adexl.historyNamePrefix" "showNameHistoryForm" 'boolean t)
    envSetVal("adexl.historyNamePrefix" "initiallyAddHistoryNameUniquifier" 'boolean nil)
