  3. How to see and get rid of design variables attached to cell...
  • Replies 9
  • Views 18152
How to see and get rid of design variables attached to cell schematic?
StephanWeber
StephanWeber over 4 years ago
having such variables in a testbench is good, but accidently I have them also in my DUT circuit schematic. No in LVS the layouters are bothered with this and need to remove them manually in CDF.
I remember, there is some skill possible to show the variables already nicely in the Library Manager. And I believe with skill you can also delete them all. Or is it even possible e.g. from schematic L GUI?
Bye Stephan
    Stephan,
    If you do right mouse button→Properties in the library manager over the cell, you'll see a property called designVarList which shows the design var/value pairs. You can get the same info with:
    artGetCellViewDesignVarList(dbOpenCellViewByType("mylib" "ampTest" "schematic"))
    (give the lib/cell/view of the cell you're interested in - to some extent the view doesn't matter since the info is stored on the cell).
    However, the definition of these on the cell shouldn't really cause any problem. More likely to cause a problem is if you have components in your schematic which use a design variable name - and removing the definition of the design variables won't fix that. Various tools can use these variables as "global" variables but they have to exist on the top level cell, and it's generally bad practice to use design variables on components for anything other than the test bench schematic. Maybe your layout colleagues are concerned about the design variables being used in the actual design hierarchy? Maybe that's what you mean by "remove them manually in CDF" (otherwise I don't know what you mean).
    ADE does give you the ability to "find" where each variable is used in the schematic hierarchy, so you could hunt them down and edit the properties to not use design variables and either have fixed values or use pPar() instead.
    If this is not what you mean, then you'll have to be clearer.
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
     Hi Andrew, I found now also in the Schematic entry a way to see the variable. I can even edit them! However, if I save and open this schematic again, then they appear again. See attached picture. We really need to delete all the variables for LVS purposes using the cds netlist.
    Bye Stephan
  • StephanWeber
    StephanWeber over 4 years ago in reply to StephanWeber
    Yes, we need a loution on cell level. I tried creating a fresh schematic like schematic_clean, but because it is under the same cell, it gets automatically the variables (which should belong to the testbench, not to the DUT).
    Bye Stephan.
    Andrew Beckett over 4 years ago in reply to StephanWeber
    That's an ADE form, and changes it in the current ADE session. If you do the "Copy to CellView" then it copies it back to the cell (exactly where I said it was stored before).
    This has no facility to delete. You have to do it the way I said before.
    I already gave you a way to do this at cell level. I still don't see why having the variables there would cause any trouble for any netlist - the only way I could see it as a problem is if the variables are actually used in the design somewhere.
  • StephanWeber
    Thanks, Andrew, I know now hot to see and edit these variables, but I still cannot delete them all. Did I overlooked something?
    The one thing I didn't mention is that you can use the same properties form to delete the designVarList property. Click in the value of the designVarList property and then hit the Delete button and then OK the form:
  • StephanWeber
    Many thanks, I think this is the solution. Our layouters have problems because these vars appear in cdl netlist (3rd party flow).
  • StephanWeber
    Layouters are happy now
