  3. why i have such a pop-up window when editing symbol
  • Views 10119
sjwprcker
sjwprcker over 4 years ago
I got such a pop-up window when finishing symbol editing, which didn't happen before.
My virtuoso version is IC618-64bit.500.24
Is there any env variable is changed ?
    This is due to these cdsenv vars:
    auCore.misc                        updateCDFtermOrder                                             boolean  nil
    auCore.misc                        queryCDFtermOrder                                              boolean  t
    Above I'm showing the defaults. If the first is set to t then it will get the popups (because of the default second env var) - the first would be telling saying that you want the simInfo updated when the terminals changed on the symbol.
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    Thanks a lot!
