  3. Can I set the order for the statistical parameter box in...
  • Views 9375
Can I set the order for the statistical parameter box in MC histograms?
StephanWeber
StephanWeber over 4 years ago
the histogram plots show a little box in which important statistical data is shown like mean, stddev, skewness, kurtosis, and Jarque-Bera value. However, if you zoom out, then the content is cut, and you will see only the first entries at the top. This is somewhat OK, BUT it would be MUCH nicer to have mean, stddev on TOP, and not Jarque-Bera. It is best to start with the most important information. Mathematically, many of these values are the distribution moments, and so there is  "native" order 1st moment=mean, 2nd moment=stddev, 3rd moment=skew, 4th moment=kurtosis, last Jarque-Bera (also min & max would be nice, e.g. if you have only one histogram.
Bye Stephan
    OK, I assume you are talking about the graph summary labels - which since ISR21 have been a separate object. If there's not enough room on the graph to display it, it does get truncated.
    I can't see any control over the order, so you should contact customer support for this. I do agree with you that we may not need to complicate things by having a controllable order though, just output them with the priority you mention.
