  3. DC and STB analysis reuse in larger sweeps
  • Subscribers 136
  • Views 10774
jehh
jehh over 4 years ago
I have observed that running a DC but especially STB analysis will provide different results, depending on whether it is part of a larger PVT sweep or singled out corners.
When running larger sweeps, does Spectre reuse information, in such a way that it can affect the end result? Is there some flag / option that can disable this behaviour?
Or is this some completely different phenomena?
BR,
Christian
Version numbers:
Virtuoso IC.6.1.8-64b.500.23
Spectre 21.1.0.303.isr5
  • Marc Heise
    Marc Heise over 4 years ago +1
    Hi Christian, yes, in sweeps Spectre is reusing the results of previous points to faster converge. So there can be a difference in the results depending on the analysis setup. Here is a public solution…
  • Marc Heise
    Hi Christian,
    yes, in sweeps Spectre is reusing the results of previous points to faster converge. So there can be a difference in the results depending on the analysis setup.  Here is a public solution which describes it and how to control it in Spectre.  This also can be controlled from within the ADE UI in the analog options or  the analysis setup:
    Article (20495347) Title: Understanding difference in results when parametric sweep is used with DC sweep w.r.t. standalone DC sweep
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AE7VIEA1
    Kind regards,
    Marc
    Andrew Beckett over 4 years ago in reply to Marc Heise
    Although I wouldn't expect this to be the case with PVT sweeps (Marc's response is definitely right for some kinds of sweeps, such as Monte Carlo or native sweeps inside the simulator) - those should end up being discrete simulations and (unless you try hard using saved node sets etc) wouldn't re-use anything from previous simulations.
    I suggest you contact support so that we can look at what is going on.
  • jehh
    jehh over 4 years ago in reply to Andrew Beckett
    Adding the swpuseprevic to the spectre arguments most definetly did affect the outputs of the sweep, allthough by very a few hundred uV changes. This was using a standard corner setup in ADE Assembler.
    It is unfortunately not always consistent, and small changes to the schematic will affect which points fail. If I do end up with a minimal representative case, I will contact customer support. However, for now, I continue with the fix proposed by Marc.
    /Christian
