  3. Simulation on design series
  • Subscribers 136
  • Views 10124
Martinsh
Martinsh over 4 years ago
I have a design with many versions. For example, my design with version number is mydesign_01, mydesign_02, ......, mydesign_99
I'd like to run a same simulation on all of the designs. Is there a way to run all the simulation in one setup?
  • Marc Heise
    Marc Heise over 4 years ago
    if you keep the top testbench schematic fixed and just need to exchange the DUT instance then you could do that with a so called "config sweep" from within Assembler.
    You need to have a config view  for your top testbench. Then it is possible to create such a config sweep in the global variables section.
    Article (20352152) Title: How to sweep views in a config view in ADE XL or Assembler
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000v6rtEAA
    Article (20494669) Title: Config Sweep in ADE Assembler
    URL: support.cadence.com/.../ArticleAttachmentPortal
    If you operate outside the GUI with pure Spectre command line you would need to script that with Ocean or SpectreMDL.
    Kind regards,
    Marc
  • Martinsh
    Martinsh over 4 years ago in reply to Marc Heise
    Dear Marc,
    Instead to sweep views of the DUT, I want to sweep the DUT cell itself. All the DUTs have same symbol and pins. Can ADE Assembler support this?
  • Marc Heise
    Marc Heise over 4 years ago in reply to Martinsh
    Hi Martin,
    I know you would need to copy all your different schematics into one cell, but I don't think there is another way doing that in Assembler if you want to  "sweep".
    Kind regards,
    Marc
    Andrew Beckett over 4 years ago in reply to Marc Heise
    Marc is correct. However, I did put together a prototype with R&D which provided a way of doing this. Please contact customer support and ask for the case to be assigned to me (please quote this text to show that I'm asking you to do this), and then I can follow up with R&D to see whether we can prioritise the enhancement or make the prototype available early.
