  3. Set ViVa subwindow size using SKILL
  • Views 10435
Brad RFeng
Brad RFeng over 4 years ago
How to set the subwindows custom array shape, i.e. 2x2, 3x10, etc. and set the size of each subwindow using SKILL?
  • Brad RFeng
    Using version IC6.1.8-64b.500.27
    Andrew Beckett over 4 years ago in reply to Brad RFeng
    I'm not aware of any SKILL function to either set the number of cells in the "custom" sub-window arrangement or the size of the sub-windows. You should contact customer support to request functions to do this.
  • Brad RFeng
    Brad RFeng over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, I will submit a request. Does ViVa continue to be improved beyond bug fixes or are there plans to replace it?
    Absolutely yes and definitely no.
