  3. Maestro expressions in yellow
  • Views 10922
david73
david73 over 4 years ago
Hi, i see this post here, and i am having the same problem
Is there an update on this?
output setup shows a yellow row - Custom IC Design - Cadence Technology Forums - Cadence Community
    The specific issues related to the yellow outputs for noise results will be fixed in IC6.1.8/ICADVM20.1 ISR28, due on the 7th October. The CCRs for this were 2674117 and 2683831 (the second was from me). The related issue of the output pane getting out of sync and not updating properly once these yellow outputs appear is also fixed at the same time. Note that there will still be yellow highlights for output expressions referring to non-existent nodes, but they shouldn't have the side effects they did before.
