  3. How to get all blocking layers touching a Pcell from inside...
  • Views 9145
How to get all blocking layers touching a Pcell from inside Pcell code
sfiswoo
sfiswoo over 4 years ago
Hi
I am writting a Pcell and want to avoid adding metal under routing blockages. The routing blockages are at the same hierarchy as the Pcell, and are not generated "inside" the pcell. I am having a hard time figuring out how to get the regions of the pcell that overlap any routing blockages. Here is how I am approaching the issue:
  1. cv = dbOpenCellViewByType( libName CellName ViewName "maskLayout" "r") ; Open the level that contains both the pcell and the blockage
  2. PGInst = dbFindAnyInstByName(cv PCELLNAME)
  3. dbLayerBlockageQuery(cv "M1" PGInst ~>bBox 0 0)
  4. Do some other stuff.
The issue is not sure how to get the name of the Pell from inside the Pcell code. Any ideas? Or maybe I should be approaching this a different way?
Cheers
    This is not a safe thing to do with PCells, as the evaluation of the PCell is not per-instance, but is per-variant. That means that if you have four instances of the PCell in the same or different cellViews with the same parameters, the PCell code will be evaluated once only - for whichever instance happened to trigger it first. Consequently you can't find the instance name of the instantiation nor (reliable) information about where it is instantiated (because it will depend on whether all instantiations have been opened yet, which is unlikely if the code is being triggered).
    So doing this within the PCell is not supported.
