  3. calcVal function referring a curve
  • Views 10993
sjwprcker
sjwprcker over 4 years ago
I want to use calcVal to cite one transient signal from test_A to test_B. The format I tried is
calcVal(XXX "test_A")    // XXX is signal name
In the result page, it shows a normal sign as a curve, but when i try to plot it, there is only one empty viva window pop out, and I got error in CIW as
It seems the expression syntax is wrong.
My virtuoso versio is IC618 64b 500.22
Anyone can help?
BR
    Andrew Beckett over 4 years ago in reply to sjwprcker +1
    Ah, that might be it. You can only use calcVal to refer to another expression not a signal . You need to have an output expression in "test_A" which is is a calculator expression - so for example: mySig…
    I found a single report of an isFile error being given when calcVal was used this way and we could not reproduce it at the time. The user restarted virtuoso and the problem went away. Not very satisfactory, but I think all you can do is try that and if that doesn't work then contact customer support.
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    The format i use calcVal is correct?
    BR
    Ah, that might be it. You can only use calcVal to refer to another expression not a signal. You need to have an output expression in "test_A" which is is a calculator expression - so for example:
    mySig: VT("/mySig")
    and then you can use: calcVal("mySig" "test_A") in the second test.
    It has to be an expression because otherwise it's ambiguous; signals are plotted for multiple analyses; DC sweeps, AC analyses, and Transient - so it could refer to three different curves and the calcVal wouldn't know which you meant (if it was supported)..
