  3. 'while' control flow for large simulation sweep in maestro...
  • Views 1393
'while' control flow for large simulation sweep in maestro run plan
cdnspg
cdnspg over 4 years ago
Running large simulation sweep with multi-parameters
parm1 p1start:p1step:p1end
parm2 p2start:p2step:p2end
... or parm sweep.
I would like to break out of the simulation sweep triggered by a condition part of output of the same simulation analysis block. Something like a 'while' control flow
        while(condition_in_sim_output, sweep_parm)
             Simulate
with condition to be a pass/fail from a condition in outputs of the simulate block and having corresponding parm values meeting condition on-hand.
The purpose is to reduce the simulations in sweep as the condition can possibly be met early in the sweep.
Any way to implement this simulation flow thru a combination of ocean script code and Run Plan in maestro?
Thanks for helping
    ShawnLogan over 4 years ago
    Dear cdnspg,
    Since I don't know the details of the simulation set you are trying to perform nor what format of the output data you are hoping to generate, I can't provide a specific answer. Nonetheless, I have often performed sets of simulations whose number is dependent on a simulation result using an ocean script. Ocean supports the while() control structure:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=oceanref.xml&title=OCEAN%20Reference%20--%20Language%20Constructs%20-%20while&hash=pgfId-1135823&c_version=ICADVM20.1&path=oceanref/oceanrefICADVM20.1/chap13.html#pgfId-1135823
    Without using oceanXL commands, the output data from your ocean script will not be written into a format readable as an Assembler/Explorer session. If you wish to place the data into a format for Assembler/Explorer, your ocean script will need to include and be compatible with oceanXL.
    Alternately, you might consider creating a run plan where the number of simulation corners of the second run is dependent on an initial run. There is an example of this methodology at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090zijUAA&pageName=ArticleContent
    I hope I understood your intent correctly and these provide some ideas to consider cdnspg!
    Shawn
