  3. How to check full netlist with LSCS
  • Views 10097
sjwprcker
sjwprcker over 4 years ago
It is simple to check netlist when sim finishes in assembler, just by right click the result.
After I switch job control mode from ICRP to LSCS, I find the netlist is not complete, which misses all circuit netlist, but only some test bench parameters.
My question is how to check full netlist in LSCS as ICRP mode?
BR
    There should be a line in the input.scs with this:
    include “netlist”
    and that contains the actual circuit rather than it being pasted into the input.scs for every point. This allows more sharing of the core netlist between points and reduces the storage overhead too.
    You can always use the hyperlinks in the simulation log to click on this file to take a look at the contents.
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    Andrew, thanks a lot!
