  3. 'while' control flow for large simulation sweep in maestro...
  • Subscribers 136
  • Views 1547
'while' control flow for large simulation sweep in maestro run plan
cdnspg
cdnspg over 4 years ago
Running large simulation sweep with multi-parameters
parm1 p1start:p1step:p1end
parm2 p2start:p2step:p2end
... or parm sweep.
I would like to break out of the simulation sweep triggered by a condition part of output of the same simulation analysis block. Something like a 'while' control flow
        while(condition_in_sim_output, sweep_parm)
             Simulate
with condition to be a pass/fail from a condition in outputs of the simulate block and having corresponding parm values meeting condition on-hand.
The purpose is to reduce the simulations in sweep as the condition can possibly be met early in the sweep.
Any way to implement this simulation flow thru a combination of ocean script code and Run Plan in maestro?
Thanks for helping
  • Marc Heise
    Marc Heise over 4 years ago
    I am not sure about the purpose of your param sweep if you want to break it early. Usually you do param sweeps to check out your design space and you want to cover all the points.
    But if this is a kind of calibration and you search for a param combination meeting your output criteria to run further test on top of it you might want   to  check out
    the option to do OCEAN pre-run scripts. Like this:
    Article (20471693) Title: Techniques for Simulating Calibrated Circuits with Virtuoso ADE Assembler
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006AicEUAS
    We also can autostop simulations using spectremdl scripts or using spice .measure , but these wont stop the whole sweep only single points.
    You could also try the optimizer to search in a param space.
    Kind regards,
    Marc
