  3. empty schematic still detect variable
  • Views 9290
sjwprcker
sjwprcker over 4 years ago
Every time when I use "design variable" --> copy from cell view, it will detect some variable not existed in schematic. Even after I empty the schematic, it still be there.
I double check, those variable not belong to the test option settings. It seems those variable been attached to the schematic.
How I can remove those variables?
BR
    This is the same as in this post where I give a way to delete them all. The other thing you can do is delete the variables you no longer need and then do "copy to cell view". The "cell view" here is a bit of misnomer; it actually saves it to the "cell" (in the property the other post refers to).
