  3. Labeling Multiple Pin names in layout
  • Views 13838
Malik Summair
Malik Summair over 4 years ago
I am trying to find an easier way to label pins in my layout. I have 4000 pins to label in my top cell.
I have tried to use find and replace but it also labels one by one.
Is there any easier way to do this job?
    Yes. Make sure you have the navigator open (e.g. from the Basic workspace, or using Window->Assistants->Navigator) and use the "Pins" section to see the pins.
    Then use Create->Label (you might then have to hit F3 to bring up the options form) and switch to the Auto mode - and then you can create labels from interconnect - you can choose which layers it will use for the label, the size and so on - see an example here:
    Then select all the pins in the navigator, and the labels will be added.
