  3. parametrizing input port for rapid IP3
  • Subscribers 136
  • Views 10613
TommasoF
TommasoF over 4 years ago
Hi all,
in my TB I have a variable called "NF_inp_port" which correspond for a given input I'd like to use on a specific corner simulation. This variable I use when running the NF simulation.
Now I would like to do the same also for the rapid IP3. So here below  I would like to parametrize the "Input Sources 1 and 2" such that for a given path I get the PORT name I desire. I tried to use some variables, then also  with VAR("variable_name") , but it didn't work out. Is there a way to parametrize this input ?
Tommaso
    ShawnLogan over 4 years ago
    Dear TommasoF,
    I did not try it, but did you happen to view the Troubleshooting article at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AEFWHEA5&pageName=ArticleContent
    This article provides a method that will vary the port in the simulation as part of a corners simulation in Assembler. From my understanding of your description, it is different than what you tried.
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    Tommaso,
    This does not appear to be possible currently. The Input Sources 1/2 appear to be treated literally (other than a mapping from schematic names to netlist names) and you cannot put a variable name in the field (I'd have expected that you'd need to use VAR("myport") to distinguish it from a literal port name, but it netlists the VAR() syntax).
    You'll need to contact customer support to request support for this .
    I tried this with Rapid IP3 with an AC analysis (i.e. for an amplifier); my guess is that it works (or rather doesn't work) similarly for a single tone hbac RapidIP3 analysis too.
