  3. MTS options do not want to open even after i set the config...
  • Views 10431
MTS options do not want to open even after i set the config view
porel1701
porel1701 over 4 years ago
Hello
My problem is that i am trying to run pspice netlist, which i imported simply by making a pspice cell view and copy/paste the netlist from the .cir file. After that, i made a symbol.
This symbol i use in a test bench. I made the config view in the test bench along with the maestro view. I followed the steps in https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000t7FzEAI&pageName=ArticleContent
The problem is that i always get the msg: ERROR (ADE-1094): The current view is not a configuration. To enable MTS mode, the design must be a configuration.
There is something here that i do not understand...so any help would be appriciated.
    Are you sure that you've actually used the config view as the design for the test? If you hover over the test name in the Data View assistant in ADE Assembler, you should see the design used, and that needs to be the config view not the schematic. If not, do Right Mouse->Design to change it.
  • porel1701
    porel1701 over 4 years ago in reply to Andrew Beckett
    Yep that was the cause....
    Thank you!
