  3. ERROR (LBRCXM-674) Quantus PVS Extraction
  • Views 11660
vdiez
vdiez over 4 years ago
Dear Cadence Community,
I am trying to run Quantus PVS Extraction on a layout, but I am having the following error:
Any help would be appreciated.
V.
  • Saloni Chhabra
    Saloni Chhabra over 4 years ago
    When running PVS, did you enable the option to generate output data for Quantus?
    Then, when you invoke PVS-Quantus, you should point to this 'svdb' directory.
    Saloni
  • vdiez
    vdiez over 4 years ago in reply to Saloni Chhabra
    Hi Saloni,
    Thanks for your reply.
    It worked, but another error appeared:
    The virtuoso, PVS and QRC versions are 6.1.8-64b, 19.15-s006 and 18.1.2-s132 respectively.
    Should I contact to Cadence Customer Support for assistance or to ihp to ask them for the _p2lvsfile file?.
    Thank you for your attention.
    V.
  • Saloni Chhabra
    Saloni Chhabra over 4 years ago in reply to vdiez
    p2lvs is a part of Quantus technology directory, so it cannot be provided by Cadence. Please check with your PDK provider.
    Saloni
