  3. command unavailable after use
  • Views 9484
Ribeiro04
Ribeiro04 over 4 years ago
 the issue in summary is that the command window close after the command is done.
so if I need to add 10 contacts I need to press the letter "o" 10 times because after I place the first via the GUI/window "Create Via" closes automatically
the same happen to path, to ruler, to move, to stretch, etc, etc, etc
 virtuoso version ICADVM20.1-64b.500.25
    Look at Options->Editor. It sounds as if you have "Repeat Commands" turned off.
    This is controlled by this cdsenv setting:
    layout                             modalCommands                                                  boolean  t
  • Ribeiro04
    Ribeiro04 over 4 years ago in reply to Andrew Beckett
    thanks Andrew
    you are correct and it's solved now
