  3. Job setup issue stuck in assembler
  • Subscribers 137
  • Views 11802
sjwprcker
sjwprcker over 4 years ago
I use assembler to sweep the corner simulation. Virtuoso version is IC618 64bit 500.22.
Job policy is mode LSCS.
distribution is LBS.
max job = 2
During the simulation, the 1st 2 corners finishes, the other 2 corners shows "netlisting finished", but never start, just be stuck there.
Any idea to solve this issue?
  • Marc Heise
    Marc Heise over 4 years ago
    Without more information it's pretty hard to tell what is going wrong.  There is an extensive debug article on support:
     Article (20480136) Title: Troubleshooting ADE Explorer, ADE Assembler, and ADE XL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090tctUAA
    You might want to enable the debug option in Assembler ( Page 65 ) , maybe that will give us some hints.  Each  distributed job is creating a log, it's
    also worth checking these.
    Kind regards,
    Marc
  • sjwprcker
    sjwprcker over 4 years ago in reply to Marc Heise
    Hi Marc, thanks for sharing.
