  3. assembler quick plot fail
  • Views 8803
sjwprcker
sjwprcker over 4 years ago
I try to use "quick plot" all in assembler result. The experiment shows that
1. non-bus signal can be quick plotted
2. bus signal like XXX<10:1> can not be quick plotted.
Is there any solution can make bus signal be quick plotted?
BR
    There was a change request (CCR) filed on this in the last few days, CCR number 2708045. You should contact customer support to request a duplicate be filed on your behalf. It seems like an oversight (bus support for output signals was added more recently than Quick Plot, but I suspect the consolidation into a bus waveform wasn't done).
