  3. Copying maestro view/simulation setup to another testbe...
  • Views 6707
Copying maestro view/simulation setup to another testbench
kenc184
kenc184 over 4 years ago
Is there a way to copy a maestro view used in explorer from one cell to another without the copy retaining the links to the first schematic?
I tried a simple library manager copy a long time ago and gave up on it, as it still linked to the original schematic, I tried a right click on the cell name in the explorer window and selected Design in an attempt to change it, but no luck.  I really just want to be able to copy over, analysis, design variables, corners etc from one schematic to another to save re-entering all that stuff.
So now, I'm back to building a new testbench for a combination of blocks and would like to include the aforementioned items from the sub block maestro view.
What's the solution?
  • kenc184
    Ah, after a little more probing, I think it's as simple as using Session>Import, then selecting the variables, corners, analyses?
    Andrew Beckett over 4 years ago in reply to kenc184
    Yes, that would be it.
