  3. Spectre parallel jobs reduce near finish
  • Subscribers 137
  • Views 12578
Pirate King
Pirate King over 4 years ago
When I have a thousand corners for example and I set 10 spectre jobs to run in parallel the 10 runs are not maintained right to the end but reduce down to eventually 1 for the last 100 runs or so which considerably increase sim time. I am using ICRP, Optimise Single-Point Run, Local Distribution Method. IC6.1.8-64b.500.19
  • Marc Heise
    Marc Heise over 4 years ago in reply to Pirate King +1
    Hi, we also do grouping for param/corner runs. Controled by this: envSetVal("maestro.simulation" "groupRunE" 'boolean t) ; E - Explorer envSetVal("maestro.simulation" "groupRunA" 'boolean t) ; A- Assembler…
  • Marc Heise
    you might try this one:
    Article (20338418) Title: How to redistribute Monte Carlo jobs in ADE XL/Assembler to better utilize faster machines?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000uxPBEAY
    MC runs are "grouped" together, so you probably have 100 runs per host. Now one of the hosts might be slow or busy which will
    hold of 100 of your runs.  Above solution discuss how to redistribute such remaining runs.
    The variable to control that is:
    In .cdsenv:
    adexl.monte minGroupSizeSplitAcrossIdleJobs int 2
    In .cdsinit:
    envSetVal("adexl.monte" "minGroupSizeSplitAcrossIdleJobs" 'int 2)
    Kind regards,
    Marc
  • Pirate King
    Pirate King over 4 years ago in reply to Marc Heise
    Thanks Marc but the issue is with PVT corner runs not monte carlo. The spectre jobs seem to automatically decrease as the last corners are approached.
  • Marc Heise
    and there is also a setting to redistribute incase one host is slower than the others:
    envSetVal("maestro.simulation" "minGroupSizeSplitAcrossIdleJobs" 'int 2)
    Could you determine if it is one host struggling  like I assumed? Or are there other problems?  Maybe you can check the
    Job logfiles to see what' s going on. Lots of guessing at the moment from my side.
    Kind regards,
    Marc
  • Pirate King
    Hi Marc, this seems to be background redistribution to reduce overall simulation time across all runs. If Max Jobs is set to 10, no matter what the clever redistribution is happening in the background in the Explorer Run Summary wouldnt you expect the jobs to remain as 10 for the whole corner set and not reduce as the last corners are approaching?
  • Marc Heise
    at the start of the simulations we group points together and assign them to a job.  That job is responsible for that group of points and will  work through them.   Without the "minGroupSizeSplitAcrossIdleJobs"  setting it will stay like that initial grouping till the very end. So there are situations where you see one job remaining, struggling with one group while all the other jobs did finish their groups already.
    The reason for that "struggling" could be  slow/busy hosts or simulations point with difficult convergence conditions, whatever.
    The redistribution system was introduced some time after the first releases of Explorer/Assembler  for exactly the reasons you bring here. Make use of the idling jobs to help finishing the rest of the points.
    Kind regards,
    Marc
  • Cadenceuser101
    Cadenceuser101 over 3 years ago
    I see similar issue, did you get resolution for this issue ?
