  3. Can I change x-axis unit for Viva PSRR plot from Output...
  • Subscribers 136
  • Views 10231
Can I change x-axis unit for Viva PSRR plot from Output setup?
StephanWeber
StephanWeber over 4 years ago
I run xf analysis to get PSRR, but I do not sweep vs frequency as usual, but vs a voltage. However, Viva x-axis unit is still "Hz". How can I change this, best permanently and only for this specific plot output (because I have also psrr vs f in another test).
Bye Stephan
    Stephan,
    I don't see this behaviour (and I find it surprising) - I am not seeing units at all if I sweep a design variable, or if I sweep a voltage source, the x-axis is in V, or a current source it's in A. I had a small problem that the direct plot form didn't seem to work - nothing got plotted (I need to check this) but plotting from calculator functions or the results browser all worked fine.
    I suggest you contact customer support - maybe there's some specifics in this case which are causing this issue.
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for your great effort. I found a mistake in my setup. With sweeping of a variable I got now no unit, which is reasonable. The mistake was in the analysis setup: frequency vs variable. Frequency was set accidentially.
    Bye Stephan
