  3. Adding CPU time as a measurement in ADE Assembler
  • Replies 14
  • Subscribers 136
  • Views 17551
sidm
sidm over 4 years ago
Hello All,
is there a way to directly see the simulation CPU time (wall clock  time) as a measurement in the  ADE Assembler Results tab? or a way to add it in the Outputs Setup tab ?
As of now I have to open the log file for each iteration to note the time and the xrun log files are pretty big.
I was hoping to have CPU time added to my tests without have to write a function.
I am using IC 6.1.8 and running transient simulations.
thanks
    ShawnLogan over 4 years ago
    Dear sidm,
    I include the following commands in my .cdsinit file to display various job statistics as outputs in Assembler. These commands will work starting with IC 6.1.8 ISR14 and ICADVM20.1.
    envSetVal("maestro.results" "enableRunStatisticInfoDisplay" 'boolean t)
    ; You can customize which items you would like to be displayed using
    ; the “defaultRunStatisticItems” environment variable like following:
    envSetVal("maestro.results" "defaultRunStatisticItems" 'string "memory,threads,jobId,host,startTime,endTime,elapsedTime")
    Do you think this might meet your needs sidm?
    I also have a UNIX script that complies the run time for each individual job and puts them in a format to use with a Microsoft Excel workbook template to plot a histogram of the run times. I've included an example of its output. Let me know if you are interested if the latter does not meet your needs.
    Shawn
  • sidm
    sidm over 4 years ago in reply to ShawnLogan
    thanks Shawn for the reply,
    yes it will be great if you can script and how to use it as I have more than 100 jobs and need to record the time taken for each of those jobs.
    regards
    Andrew Beckett over 4 years ago in reply to sidm
    You could of course just enable:
    (the default is to output all the statistics), and then change to detailed transpose, and then hit the "Save" button to save to CSV. I'm sure you could then manipulate the elapsedTime column in a spreadsheet...
  • sidm
    sidm over 4 years ago in reply to Andrew Beckett
    thanks for the reply , I ran the below 2 commands in CIW just to be sure that they are set to true,.but I still don't see the additional parameters in the Results tab even after restarting the assembler view. Am I missing something here ?
    thanks
    ShawnLogan over 4 years ago in reply to sidm
    Dear sidm,
    If you still have an interest, I have placed a compressed file with the UNIX scripts, a README file, and a Microsoft Excel file that you may use to automatically create histograms of your simulation times from an Assembler run. The contents of the README file are below the link.
    Let me know if I can answer any questions if you happen to want to try it.
    Shawn
    The compressed file is at URL:
    https://www.dropbox.com/s/vfowskyj6da0uly/check_timexl_101922.zip?dl=0
    README file contents:
    1. Place UNIX scripts check_timexl and find_timexl at the top level of your
    Assembler/Explorer results directory.
    2. Alternatively, place in your ~/bin directory if ~/bin is in your UNIX
    search path
    3. Make each file executable with the following commands:
    $ chmod +x check_timexl
    $ chmod +x find_timexl
    4. File find_timexl is called by check_timexl
    5. To create a comma-separated file with all simulation times for a given
    dataset, for example, Interactive.1, enter the command:
    $ check_timexl 1
    check_timexl will scan all the simulation output logs in Interactive.1 and
    create a comma-separated-variable file "check_timexl.csv".
    6. Download file "check_timexl.csv" amd replace contents of tab "" in Microsoft
    Excel workbook "sim_time_check_timexl_sml_041522.xlsx". Optionally enter desciption
    of circuit simulated and details in tab "Variables_and_instructions". The
    workbook automatically creates histograms of the simulation times in
    hours, seconds, and days.
    sml 10/19/22
  • sidm
    thanks a ton ! Shawn I will surely use the script
    But can you please also share some insights on why I still don't see the additional parameters in the Results tab even after restarting the assembler view. Am I missing something here ? I was expecting to see an additional row added in the Results window something like transtime or something similar...
    thanks
    Did you re-run the simulations after settings those env vars? It doesn't record the data (I believe) if you didn't run with those settings. Also, I'm assuming there was no warning in the CIW when you entered them - which would happen if you're using too old a version. I can't quite remember when these were introduced. Just checked, it was IC6.1.8 ISR14 and ICADVM20.1 - see How to get resource usage and simulation run statistics displayed in the results tab in ADE Assembler or Explorer
  • sidm
    yes I re-ran the simulation after re-starting Assembler view.
    What are the measurement names that I should be expecting to see in the Results tab of the assembler view.
    I am using IC6.1.8-64b.500.27
    regards
    The article I linked to shows the outputs you'd expect. They are called things like this:
    sim_Peak_Memory: Peak memory consumption for Spectre
    sim_Threads_Used: Number of threads used by Spectre
    sim_JobId: LSF job identifier, shown only when you are using the LBS distribution method
    sim_Host_Name: Name of the host on which simulation was run
    sim_Circuit_Nodes: The node number in the Spectre inventory
    sim_Started_Time: Start time of the simulation run
    sim_Finished_Time: End time of the simulation run
    sim_Elapsed_Time: Elapsed time of the Spectre simulation run
    Is your simulator "spectre"? This won't work for non-Cadence simulators (I believe; I've not checked though).
  • sidm
    thanks Andrew yes I am using SpectreX though my simulator is set to AMS as  I am running AMS simulations. I also don't see the Run Statistics option (after running the  envSetVal command) as shown in the article link you shared -
