  3. Measuring across corners or parameters, then equation using...
  • Subscribers 136
  • Views 10821
Measuring across corners or parameters, then equation using results
TempViator
TempViator over 4 years ago
I would like to calculate one value using measured values from several runs of the same circuit using different parameters.
The calculation is an arithmetic equation, not just an average, max, min, stddev of the measured values.
For example, result 1 - result 2 - result3
I have tried this by making each run its own corner, but I don't see how to write expressions to grab the 3 values, and then an expression to do the math.
I have tried this by making each run part of a Global Variables sweep, but I must use Grouped Parametric Sets, and again, I don't see how to write expressions to grab the 3 values, and then an expression to do the math.
It seems like I need the following:
1. A version of the 'value' function that has a way to specify either a Corner or choose amongst the combos in a Grouped Parametric Set.
2. A 'post all sims'  calculation using other measurements ... I think this can be done using an EvalType other than 'point'.
Is there a best way to do this, perhaps I am missing something easy?
(tool version: IC6.1.8-64b.500.7)
Thanks.
  • amac
    amac over 4 years ago
    I tried creating a second test and using calcVal to retrieve the points created by the sweep; in your case it should be:
    calcVal("1" "FloatingNodeCheck_nominal" ?matchParams list(list("resFloat_resVal" "1G") list("resFloat_runMode" "-1") ) )
    (similar for the other two points)
    If you specify a name for the 3 outputs created you can use math functions on them in the same "calculation test".
    I am still looking for a method to combine named outputs into a waveform
