  3. noise vs s-paramter simulation for noise figure
  • Subscribers 137
  • Views 13822
asetji
asetji over 4 years ago
I have a differential amplifier, 100 ohm i/p n o/p impedance. I am trying to get an idea of the noise figure for which i have tried both noise analysis and parameter analysis. However, i get different results from the two analysis.
The noise analysis report 26 dB of NF and SP denotes 14 dB of NF. Gain reported by two simulations (transfer function in noise and S21 in SP) are almost similar.
For noise simulation, i am using a port with 100 ohm resistance as i/p and differential nets as o/p.
For SP, i have two ports with 100 ohm resistance.
So, what I am doing wrong and which analysis i can trust. I don;t have a measured data for this exact scenario so cannot really compare. Gain reported via both simulations looks correct.
BR
Edit: Also noticed that NFmin from SP shows much higher values compared to NF from SP, which is another mystery for me.
    ShawnLogan over 4 years ago
    Dear asetji,
    What is the source of your S-parameter file? Is it measured data or simulated data? Have you examined your S-parameters in ViVA? If I were Tawna Wilsey, whose background and knowledge I can only aspire to, she would immediately ask you to study your S-parameters carefully as it is very common to get incorrect simulation results if the S-parameters are not appropriate for the simulation. I might suggest you examine Tawna's note(s) at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    If you are not familiar with the Rapid Adoption Kit (RAK) for Noise and S-Parameter Measurements of a FET at URL:
    it might be worth reviewing it to make sure your simulation set-up is not overlooking something.
    Sorry I cannot provide more specific advice asetji!
    Shawn
  • asetji
    asetji over 4 years ago in reply to ShawnLogan
    Thanks ShawnLogan,
    unfortunately my reference key is expired so cannot access the support documents that u have referred.
    Regarding the circuit, it is a mixture of extracted schematics (R,C,CC) and EM simulated layouts.
    BR
    ShawnLogan over 4 years ago in reply to asetji
    Dear acetyl,
    Rats - that is too bad as I think they might provide some insights into your quandary!
    I assume the EM simulated layouts are modeled as S-parameters. If so, you can still examine the S-parameters for the relevant subcircuits in ViVA directly. From te=he ViVA window, under the menu item File, choose Open Results.... Select your S-parameter file. Its sufficient should be something like <s_paramter_filename>.snp where n is the number of ports.
    Meanwhile, perhaps you could ask whomever is responsible for your Cadence tools for access to the On-line support portal.
    Shawn
  • asetji
    asetji over 4 years ago in reply to asetji
    finally got the renewed key and had a look at the support documents.
    However, they didn't really help me in solving this mystery.
    Any other ideas?
    BR
    Dear asetji,
    Any other ideas?
    Great!  How did the S-parameters for each file you are using look? Is the frequency resolution sufficient? What are your simulation settings? Are your networks non-linear? Are your tool versions consistent with those recommended in the Cadence On-line support articles whose links I included?
    Speaking for myself only, without more details about your simulation setups, S-parameter files, and circuit, all I can do is guess by asking questions about them. Andrew often recommends that one contact customer support if the details are proprietary.
    Sorry I cannot be more help...
    Shawn
  • Brad RFeng
    Brad RFeng over 4 years ago in reply to ShawnLogan
    Hi asetji,
    In situations like yours I start by creating a simple test case circuit that I fully understand and know in advance what the simulation results will be. Perhaps a simple text book circuit or create your own. Simulate the test case circuit and experiment with the test bench until you get the expected results. If you can't get the simple circuit to work as expected there is no benefit in wasting time on a more complicated circuit. You must conquer the basic circuit simulation first. Then add more complexity to the circuit (perhaps replace the IMN with s-parameter file) and repeat.
    Brad
