  3. Automatic Loading of Corner File
  • Views 10419
Ali Nikoofard
Ali Nikoofard over 4 years ago
What is the easiest way to automatically load the previously made corner settings every time the virtuoso command is ran? Manually we have to import corners which is not optimum.
Thanks!
    ShawnLogan over 4 years ago
    Dear illaoi,
    Did you happen to see this article when you searched the Cadence On-line support portal? It seems this might accomplish what you descibe in your post.
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=adexl.xml&title=Virtuoso%20Analog%20Design%20Environment%20XL%20User%20Guide%20--%20Simulating%20Corners%20-%20Setting%20Up%20a%20Default%20Set%20of%20Corners&hash=pgfId-1037158&c_version=IC6.1.8&path=adexl/adexlIC6.1.8/adexlCorners.html#pgfId-1037158
    I hope this helps illaoi,
    Shawn
  • Ali Nikoofard
    Ali Nikoofard over 4 years ago in reply to ShawnLogan
    Shawn,
    Thanks for sharing the solution, but I can only use the material in cadence community.
    ShawnLogan over 4 years ago in reply to Ali Nikoofard
    Dear illaoi,
    If you are using Cadence tools, whomever administers your Cadence tools should be able to provide you access to the Cadence On-line Support portal. I would consider speaking with him or her to gain access. Most all of the questions you posted can be answered by a quick search on the support portal. There is a wealth of background information I think you might find very useful.
    Shawn
