  3. Combining Histograms of Multiple Tests?
  • Subscribers 136
  • Views 10074
eyeseedesign
eyeseedesign over 4 years ago
I have two independent tests in one of my adexl testbenches that I am running Monte Carlo on. I point to the same cell in both tests but the difference is that I have a different vector file used for generating a load response on the output. I know there is a way to combine multiple corner sets within a testbench for a given Monte Carlo run, but I was wondering if it was also possible to combine the histograms of two tests? If this isn't possible my next step was going to be putting two of these blocks in 1 test which I was hoping to avoid.
Thanks!
  • eyeseedesign
    Hi again. I figured it out. I ended up combining two histograms within one test and copied the combined expression to the calculator. From there I followed the syntax of the equation. Here is a reduced version of what I did:
