  3. Can we do .PZ analysis for the circuit that uses inductor...
  • Views 9377
Can we do .PZ analysis for the circuit that uses inductor with n-port S-parameter
RFStuff
RFStuff over 4 years ago
Dear All,
Kind Regards,
    Assuming you're talking about using the pz analysis in Spectre, then I would say that the results are going to be challenging to interpret. If you use the nport with the default (linear) interpolation method, then it's a frequency dependent component and it will analyse the poles and zeros at a fixed frequency. You could use interp=bbspice on the nport which would give you the poles and zeros of the rational model fitted to the s-parameters, which may be somewhat meaningful.
  • RFStuff
    RFStuff over 4 years ago in reply to Andrew Beckett
    Thanks Andrew.
