  3. Can I display connections for a node?
  • Replies 10
  • Subscribers 137
  • Views 13993
ichiro
ichiro over 4 years ago
Hi all,
Can I display connections about only one node using the below function?
Schematic: Options->DISplay->Show Direct Connections
Or How can I realize it by SKILL?
Ichiro
  • mschw
    mschw over 4 years ago
    Dear Ichiro
    maybe this article on support.cadence.com can help you.
    Matthias
    Andrew Beckett over 4 years ago in reply to mschw
    Thanks for pointing that out Matthias. I was going to suggest an alternative approach, using Options->Display->Dynamic Net Highlighting which will dynamically highlight all connections on the net you hover over - also available via View->Net Highlighting. This can be enabled with SKILL:
    envSetVal("schematic" "schDynamicNetHilightOn" 'boolean t)
  • ichiro
    ichiro over 4 years ago in reply to mschw
    Hi Matthias,
    That's the answer I was looking for !! I'll try to the skill code.
    Thanks!
    Ichiro
  • ichiro
    ichiro over 4 years ago in reply to Andrew Beckett
    Thanks for practical idea. I'll use it if I can not work the Matthias idea well.
    Ichiro
  • ichiro
    ichiro over 4 years ago in reply to ichiro
    Hi Matthias,
    I saved the script as "FL.il" to current directory run Virtuso. In CIW, I typed "load("./FL.il") and enter key. Then returned below.
    load("FL.il")
    function CCSAddFlightProbeAll redefined
    function CCSAddFlightProbeSelected redefined
    function CCSDeleteFlightProbesSelected redefined
    function CCSDeleteAllFlightProbes redefined
    t.
    But "Shift + any key(9 or 0 or 8 or 1)" can't work well..
    Do you have any idea?
    Ichiro
  • mschw
    mschw over 4 years ago in reply to ichiro
    Dear Ichiro,
    i just tested it on my setup and the bindkeys do not work there either (I don't have time to investigate that on my own).
    I tried replacing "Shift" with "Ctrl" - that worked for me.
    Regards
    Matthias
    The best thing to do is to look at the key sequence you'd get if trying to add a bindkey via Options->Bindkeys. For example, for me shift-8 gives:
    <Key>*
    and shift-9 is
    <Key>)
    This changed a while back (after the article was written, I believe). I thought there was an article specifically talking about that, but I couldn't find it...
  • ichiro
    Hi Matthias and Andrew,
    Finally, I was able to get it to work!!
    It required redefinition to reserved bind keys, not assignment to free keys.
    Can the color be changed every creating flightline ? I could realize with "random(9)"...
    Ichiro
    Andrew Beckett over 4 years ago in reply to ichiro
    I made a small change to cycle through colors - see the attached (this has redefined bindkeys which should work, at least on my keyboard; you may want to change the keys used to suit your needs):
     * DISCLAIMER: The following code is provided for Cadence customers       *
     * to use at their own risk. The code may require modification to         *
     * satisfy the requirements of any user. The code and any modifications   *
     * to the code may not be compatible with current or future versions of   *
     * Cadence products. THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, *
     * INCLUDING WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED         *
     * WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.         *
    procedure(CCSAddFlightProbeAll()
      let( (win cv)
      win=hiGetCurrentWindow()
      cv=geGetWindowCellView(win)
      ; cycle through colors
      CCSAddFlightProbe.color=mod(((CCSAddFlightProbe.color)||8)+1,10)
      foreach(netname cv~>nets~>name
            geMakeProbeWithColor(?window win
                 ?color list(lsprintf("y%d" CCSAddFlightProbe.color) "drawing")
                 ?object list(netname)
                 ?probeType "net"
                 ?displayStyle "flight")
        ) ; foreach
      ) ; let
    ) ; procedure
    hiSetBindKey("Schematics" "<Key>(" "CCSAddFlightProbeAll()")
    procedure(CCSAddFlightProbeSelected()
      let( (win)
      foreach(netname cadr(cadr(car(hsmGetSelectedSet(?type 'net))))
                 ?probeType "net"
        ) ; foreach
      ) ; let
    ) ; procedure
    hiSetBindKey("Schematics" "<Key>*" "CCSAddFlightProbeSelected()")
    procedure(CCSDeleteFlightProbesSelected()
    let((win probeList SelectedNets)
    probeList=geGetAllProbe()
    SelectedNets=cadr(cadr(car(hsmGetSelectedSet(?type 'net))))
    foreach(probe probeList
    	when(member(probe~>pathObjectName SelectedNets)
    	geDeleteProbe(win probe)
    	); when
    ); foreach
    );let
    ); procedure CCSDeleteFlightProbes
    hiSetBindKey("Schematics" "<Key>!" "CCSDeleteFlightProbesSelected()")
    procedure(CCSDeleteAllFlightProbes()
    let((win probeList)
    ); foreach
    );let
    ); procedure CCSDeleteAllFlightProbes
    hiSetBindKey("Schematics" "<Key>)" "CCSDeleteAllFlightProbes()")
  • ichiro
    Oh! That's perfect answer for my what I want.
    Thank you Andrew!
    Ichiro
