  3. How can I add search path for matlab files outside working...
  • Views 9872
How can I add search path for matlab files outside working directory?
delgsy
delgsy over 4 years ago
I want to organize my matlab files into 1 folder outside working directory.
I tried added this line into .cshrc file:
set path = ( $path $HOME/clio/script )
I can see it in the terminal when I execute echo $PATH.
but still the matlab expression in the output expression window does not work.
Is there anything that I can try?
    More of a MATLAB question than an ADE question really. For MATLAB, scripts are found using $MATLABPATH, not $PATH.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    Thanks.
    I found this in matlab RAK. I will try once the current simulation finishes.
