  3. My settings in Job Setup, Run Options, Save are always reset...
  • Views 11710
My settings in Job Setup, Run Options, Save are always reset back
delgsy
delgsy over 4 years ago
My settings in Option --> Job Setup, Run Options, Save are always reset back.
For example in this Job Setup window, Max Jobs is always reset back to 1 after closing the maestro or cadence.
Is there a way make it remember the last setup?
    Change the Job Policy Name to something other than "Maestro Default" (using the Save button). The Maestro Default is (as the name suggests) the out-of-the-box default.
    There are then three cdsenv settings that can alter which of your custom job policies are used by default (first for ICRP, second two for LSCS):
    adexl.icrpStartup                  defaultJobPolicy                                               string   ""
    maestro.lscs                       defaultNetlistingJobPolicy                                     string   ""
    maestro.lscs                       defaultSimulationJobPolicy                                     string   ""
