  3. How to put Cadence expr output to Matlabexpr
  • Views 8244
grooo
grooo over 4 years ago
Hi there,
I'm trying to put Cadence expression output into a Matlabexpr. For example, I have the following output:
Name / Type / Detail
xxxx   / expr  / cadencefunction(.....)
yyyy  / matlabexpr  / matlabfunction(..... , xxxx)
So basically, I tried inputing xxxx (cadence function name) into yyyy (matlab expression), but cadence gave me an error.
Is there a specific way I should refer to the Cadence expression?
+ Also, how can I input Cadence Variable into a matlabfunction? the traditional VAR("variable") gave me an error.
