  3. Availability of Sensitivity results in Assembler after corner...
  • Views 9182
Availability of Sensitivity results in Assembler after corner run?
StephanWeber
StephanWeber over 4 years ago
after a corner run (e.g. for all supply voltage combinations), sometimes the icon to get the Sensitivity Results is active, sometimes it is grayed out. I wonder why? Under which conditions can I get the nice sensitivity tables?
Is it correct: If I see "Finished with errors" I cannot get the sensitivity results? Usually I get this just because e.g. one analysis was disabled (leading to eval err). However, it would be great to get sensitivities at least for all the good outputs.
Bye Stephan
    Stephan,
    Which run mode are you using? I would expect this to appear in Worst Case Corners, Sensitivity Analysis etc - but not in a normal "Single Run, Sweeps and Corners" (I would have expected it to have computed the sensitivities otherwise).
