  3. Layout Editor: Pin Visibility for Sub-Levels
  • Subscribers 136
  • Views 13639
sgcad
sgcad over 4 years ago
I'm using Virtuoso 6.1.8. and wonder if there's a way to alter the layout editor behavior as follows: Currently, if I press ctrl-f, only the instance drawing layer (showing the instance outlines) and pins/labels of the topmost hierarchy level are visible. To quickly locate pins/labels of placed instances, it would be very useful that also pins/labels of lower hierarchy levels were visible (in fact preferably only the single next level).
Is there a way to set such a behavior? So far I didn't find any suitable option.
Thank you for your help!
    This is what Options->Display->Instance Pins does (well, it does it for pins - you have control whether instance pin names are shown too). You don't have the option (I believe) to show labels from one level down.
  • sgcad
    sgcad over 4 years ago in reply to Andrew Beckett
    Excellent, thanks. Just for the records:
    graphic drawInstancePins boolean t
    in the .cdsenv sets this as default.
    Andrew Beckett over 4 years ago in reply to sgcad
    Actually, it should be:
    layout drawInstancePins boolean t
    There is also the graphic tool setting, but the layout setting is more specific (in fact the default for the graphic variable is t anyway, but the default for layout is nil).
