  3. Binding issue with digitally synthesized block
  • Views 8286
sidm
sidm over 4 years ago
Hello ,
I synthesized a digital block from it's .v code and imported the GDS into Virtuoso. I also imported the same .v file into Virtuoso to create schematic corresponding to the .v code
I am seeing imported GDS is showing unbound instances which are all from digital pdk lib.
What can be the issue and how can I resolve it ?
I am using IC618
Also when I instantiating this digital block at the top level for routing the flight lines are not visible for connections at the top level.
thanks
