  3. Is thre a simulator function that can control the simulator...
  • Views 1642
Is thre a simulator function that can control the simulator's temperature in Verilog AMS?
SpiceMonkey
SpiceMonkey over 4 years ago
I'm dong Mixed signal simulation using Xcelium. I need to change temperature over time, I know this can be done in Analysis-transient-dynamicParameter, but this is not convineient for my verificaiton work. Is it possible to control simulator's temperature by any verilogAMS function? Thank you!
    You should be able to use the $cds_set_temperature() system function to do this. Search for "cds_set_temperature" in the documentation. Andrew
  • SpiceMonkey
    SpiceMonkey over 4 years ago in reply to Andrew Beckett
    thank you!
