  3. How to re-use a setting for Assembler Results Table (Detailed...
  • Views 8756
How to re-use a setting for Assembler Results Table (Detailed Transposed)?
StephanWeber
StephanWeber over 4 years ago
I run a huge corner analysis, and need not all outputs, signals, etc. So I disabled the waveforms, etc. and used the mouse to hide many many many columns. However, than virtuoso crashed (maybe from our IT). And I need to do it again. Isn't there a way to get my old setting back? Or is this only possible for filters?
Bye Stephan
    Presumably you didn't save the maestro view? If not, there's not anything you can do to get it back; if it was saved, I would expect it to be the same when you opened it again.
