  3. How to show process corner information inside the plot?
  • Views 10089
delgsy
delgsy over 4 years ago
I think it would be nice if I can show the corner information inside the plot, instead of on the left side.
I found that the legend setting has 'inside' option but I cannot find a way to show the corners.
It would be better also if there is a way to put this process corner information closer to the corresponding trace.
Is there a way to achieve this?
    The inside legend is intentionally terse, and not really intended for having lots of traces on a graph. You may be better off using above rather than inside? If we were to display all that information on the inside legend, the graph would get obscured pretty quickly.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    I did try above as well. but the information is too much. I actually just want to show the process corner info, e.g., ff, sf, etc.
    Andrew Beckett over 4 years ago in reply to delgsy
    All I can suggest is that you contact customer support, as this would need an enhancement request (I'm pretty sure it can't be done right now).
  • delgsy
    ok..thanks for the information.
