  3. VerilogA - command: $root
  • Subscribers 136
  • Views 1781
rrihak
rrihak over 4 years ago
Hello I would like to ask, if there is any way how to use command $root in VerilogA language for current reading in the top cell of schematic? I know I can use $root for reading voltage, is it similar for current or there is another command?? Thanks
  • MarcelAhmedzai
    MarcelAhmedzai over 4 years ago
    One way to obtain votlages, current and other parameters is to use the $cds_get_analog_value command. Also aliased to $cgav for short.
    Unfortunately you are not able to use the $root with $cgav. So instead, you can take advantage of the string manipulation commands available to you in VerilogA to retrieve the hierarchical path which can then be used in the $cgav.
    Here is an example of the code you could use;
    module getDiff1 ( );
    real vdiff;
    string instPath, instPath_1, instPath_cgav;
    integer pn1;
        //include functions needed for string manipulation
        `include "shdl_strings.vams"
    initial begin
        //Retrive the instance path to where this instance is in the design
        $swrite(instPath, "%m");
        $strobe("Path is %s", instPath);
        //Find the index for where the last "." was in the extracted instance path
        //pn1=shdl_strrchr(instPath, ".");
        pn1=shdl_strrchr("%m", ".");
        //Extract the substring from the instance path for the level above this
          instPath_1=instPath.substr(0,pn1-1);
        $strobe("Path -1 is %s", instPath_1);
        //Construct the string for the cgav
        $swrite(instPath_cgav, "%s.I0.vdiff", instPath_1);
    //    vdiff=$cgav("I0.vdiff", "potential");
    //    $strobe("Vdiff is %f\n", vdiff);
    end
    always #0.5 begin
        //Use cgav
        vdiff=$cgav(instPath_cgav, "potential"); ;;<-- FOR CURRENT YOU CAN USE "flow" HERE
    end
    endmodule
    As you can see in my comments the use of the $cgav can be used to get the current by switching out the "potential" to "flow";
    $cgav(instPath_cgav,"flow")
    More details of using the $cds_get_analog_value can be seen in the documentation.
    Kind regards
    Marcel
