  3. common mode level in vcvs
  • Subscribers 136
  • Views 14641
paulinho
paulinho over 4 years ago
the vcvs in analoglib is by default fully differential (both input and output is differential). Say if i give an input of 1.5V to both input terminals (vcvs having a gain of 1), and I want the same values at the output, how do I do it. Even though the differential output is 0V, the common mode levels at the output seem to be at some arbitrary level.
    ShawnLogan over 4 years ago
    Dear paulinho,
    Would something like this work in your application?
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    Isn't the simplest solution to have two vcvs sources with the minus pins all connected to ground? Then have the two + input pins connected to the two input voltages, and the two output + pins will reflect the input pins. It's not really a differential input you want for a controlled source, if I've understood your description properly.
