  3. Using 'temperature' as a design variable breaks calcVal...
  • Views 2530
Using 'temperature' as a design variable breaks calcVal functionality
Kevin Buck
Kevin Buck over 4 years ago
I'm using the calcVal function to use a found trim value from my first test in a second and third test and it works as expected. I've added a fourth test that creates a design variable called temperature and I'd like to set it using the calcVal function output of my second test. For some reason though this breaks the calcVal function in the second two tests. If I disable the fourth test everything works again as expected.
If I enter a hard coded value for temperature in the fourth test then it still breaks the calcVal functionality in the second and third test.
Is this a bug or am I missing something?
I'm using Cadence version IC6.1.8-64b.500.9.
  • Kevin Buck
    Kevin Buck over 4 years ago +1
    The issue with my fourth test is now clear, there was a mismatch in the number of parameters and the ?matchParams argument helped to clear it up. I still don't understand why this broke the second and…
  • Kevin Buck
    I still don't understand why this broke the second and third test which were only dependent on the first, I resolved that error by adding the ?getFirstSweepPoint t argument.
