  3. How To Add Arguments to systemVerilog Extraction
  • Views 9638
YB36
YB36 over 4 years ago
Im facing several issue/complication when doing C&S on system Verilog view - that I pretty much sure I can solve by adding arguments to the xrun command.
I found the solution of creting hdl.var file and adding arguments there by  using DEFINE XMVLOGOPTS.
but Im facing difficulties with this file.
For instance - Im trying to suppress several noisy warnings by  adding "-nowarn DLCLIB:DLCLAP " . I tried it directly with xrun command - and it works like a charm - giving so much quite in my compilation. When adding it using the hdl.var file Im getting this massage in the log :
  The following environmental variables have been detected.
These options will be used directly by the executables and ignored by xrun.
XMVLOGOPTS: -nowarn DLCLIB:DLCLAP
well it is sound like it knows what it doing (I don't get it) - buy the hell rain of noisy warning is back.
so I wandering - is there any good way to give argument to xrun using hdl.var (without being told some stuff about executables )?
Im using vmac 22.07.06_rc.
