  3. The region of operation of MOS transistor
  • Replies 12
  • Views 19125
PhD Student
PhD Student over 4 years ago
HI,
I am going to design analogue circuit, and I need to show the region of operation for all transistors in the circuit after running the simulation.
My issue is: I tried two methods to show the region of operation:
The first method is: from the schematic --- > View ----> Annotations -----> setup
When I wanted to change one of the listed (such as ids, gm, ron,..etc) to be region, then I could not find the region with them.
The second method is: From the ADE L------> calculator------> select OP
When I select one of the transistors in the circuit, I see the same list (ids, gm, ron,..etc) without 'region'.
Please, how can I solve this issue? I need to show region of all the transistors, but I cannot.
Regards.
    I believe most transistor models have a region operating point parameter so the most likely explanation is that the model is a subckt model and there is information in the CDF (opParamExprList) to tell…
    Andrew Beckett over 3 years ago in reply to PhD Student +1
    PhD Student said: The device is a transistor (MOSFET) as in the title of this post (The region of operation of MOS transistor). This is getting rather frustrating, since you keep failing to answer simple…
    This is getting rather frustrating, since you keep failing to answer simple questions and only give vague information. I spent a bit more time on it, but I've reached my limit - for anything further, please contact X-FAB since this is their kit, not Cadence's.
    Anyway, what I did:
    1. There are 19 MOSFETs in the PRIMLIB for the PDK version I have (I picked one metal stack arbitrarily but I don't think that would affect it). More if you include MOSCAPs. So "the device is a transistor" is not terribly helpful.
    2. The Spectre simulation information is not blank for any of them - so I have no idea why it would be blank for (say) PRIMLIB/nd5 or PRIMLIB/ne5 (for example). Perhaps your setup is wrong or you were looking at the wrong thing.
    3. I see that opParamExprList is used for all 19 MOS devices, and for a couple I checked (at least) it did not include any mapping for "region". The mapping retrieves the information from a device within a subckt model (.m1 or .m2 from the few I looked at), but they've not included region.
    4. I could explain to you how to modify the CDF to update it to add additional operating point parameters, but I have little confidence that you'd be able to do this correctly from instructions on a forum unless they were extremely prescriptive. The fact that your CDF form is blank suggests that something is not right. Also, you'd need write access to the PDK, and most people do not want to alter the PDK setup for fear of breaking it.
    So this reinforces my view that you should contact X-FAB - maybe they can update the PDK or maybe they can provide you support on getting what you want from their technology.
    Good luck,
  • PhD Student
    PhD Student over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for the reply.
    Regards.
